CASP 6.1 - Chương trình tính toán xếp dỡ tàu công.
Bài gửi by klv12gcn on Fri Sep 23, 2011 10:37 pm
What is CASP?
Stowage planning is a definitely complex and difficult job involved with various factors. It needs extraordinary manpower and time if you ought to do it manually. The Stowage planning is important from the view of operation because it affects an operational efficiency, ¡°just-in-time¡± in vessel schedule & cargo delivery, sea worthiness of vessel and so on. The solution, CASP, integrated automated stowage planning has been designed and developed to optimize stowage planning to save your time and to increase stability of ship on the basis of operational concept and practice.
CASP offers total solution to manage and control stowage planning as it integrates systems with all necessary and related regulations/rules and with EDI communication.
NOTE: CASP in the manual hereafter means CASP Windows version. You could have the message ¡°Incorrect Bay plan Version.¡±, while loading a file in CASP utility program. When CASP program has been upgraded and modified, a version of a file you are going to load can be different with yours. Then go back to CASP program and load the *.asc file. If you are asked what a version of the file is, select its version and click the OK button. When you convert the file, you are able to use the utility again.
Gerneral Benefit
- A Certification of Year 2000 Compliance
- Supporting a convenient user interface
- Easy to use and convenient user interface such as Cool menu, Cool bar, etc.
- Improvement of Performance
- Windows 32bit architectures improve its performance that Windows95 provides over 3.1.
- Increased Reliability
- Windows 95/98 and NT workstation provides the highest level of protection of 32bit application. An errant application is much less likely to disturb other application or system.
- Faster Printing
- Windows98 features a new 32bit printing sub-system that reduces time spent on waiting for print job to be done and improves system response when jobs are printing background.
- Easy to remove program and file
- At the end of installation, CASP is easy to be removed. You can delete some working files while using a file-loading window.
- Supporting High resolution
- Do you have high-resolution mode of monitor, 1280X1024 or higher? Then, you can make a stowage plan on the full screen of General Plan.
- No need to scroll up and down.
Download:
Code:
http://www.mediafire.com/?jscs83azzm9v4q3
klv12gcn
klv12gcn
Tổng số bài gửi : 170
Điểm kinh nghiệm : 224
Ngày tham gia : 09/04/2011
Nơi làm việc : Wagenborg Shipping BV
Đến từ : Buôn Ma Thuột, Đắc Lắc
Xem lý lịch thành viên http://kimlươngvương.vn
Re: CASP 6.1 - Chương trình tính toán xếp dỡ tàu công.
Bài gửi by kevin3378 on Mon Jul 08, 2013 5:24 pm
Link die rồi pác ơi. Upload giúp em với
kevin3378
kevin3378
Ngày tham gia : 12/06/2013
Bài gửi by still_love_u_4ever on Wed Aug 21, 2013 9:01 am
link die rùi bạn ơi
still_love_u_4ever
still_love_u_4ever
Điểm kinh nghiệm : 6
Ngày tham gia : 29/10/2012
Bài gửi by quangdinhho on Sun Nov 24, 2013 4:50 pm
không down được bố già ơi!!!
quangdinhho
quangdinhho
Ngày tham gia : 21/11/2013
Bài gửi by lamdad on Thu Jun 12, 2014 1:19 pm
ai còn phần mềm CASP không cho mình xin với
lamdad
lamdad
Ngày tham gia : 10/06/2014
