DraftSurvey Lt (Phần mềm miễn phí tính toán giám định mớn nước)
Trang 1 trong tổng số 2 trang 1, 2  Next
Bài gửi by Bố già on Tue Oct 26, 2010 11:58 am
DraftSurvey Lt is a user-friendly Draft Survey calculation program for Merchant Navy Officers and Marine Surveyors. It is designed to take care of complete draft survey needs. Its specially useful for marine surveyors as it does not require the full input of hydrostatic data, only two lines of hydrostatic data relevant to the calculation at hand needs to be entered to calculate the result. The final survey can be undertaken without entering the initial draft survey data if the initial net displacement cell is filled-in in the final draft survey form. This is very useful for a surveyor who may not have conducted the initial survey, he knows the initial net displacement and can use just this information together with this program to quickly calculate the results. The purpose of DraftSurvey Lt is to save time which can be spent to take more careful measurements which can greatly increase the accuracy of the survey results and avoid the mathematical mistakes due to shortage of time.
Được sửa bởi Bố già ngày Wed Apr 10, 2013 5:47 pm; sửa lần 1.
Re: DraftSurvey Lt (Phần mềm miễn phí tính toán giám định mớn nước)
Bài gửi by thoaivtc on Wed Apr 13, 2011 8:55 pm
thanks
thoaivtc
thoaivtc
Tổng số bài gửi : 20
Điểm kinh nghiệm : 22
Ngày tham gia : 23/10/2010
Nơi làm việc : Prime Shipping Group
Đến từ : TP HCM
Bài gửi by goda5dago on Mon Jul 11, 2011 9:50 am
thank you very much!
goda5dago
goda5dago
Tổng số bài gửi : 16
Điểm kinh nghiệm : 24
Ngày tham gia : 07/07/2011
Bài gửi by hmducst on Tue Aug 30, 2011 1:59 pm
sao e ko chạy được nhỉ? nó báo : " erro launching installer" help me!!!
hmducst
hmducst
Ngày tham gia : 30/08/2011
Bài gửi by lakientrung on Thu Sep 08, 2011 2:14 pm
Thanks so much
lakientrung
lakientrung
Tổng số bài gửi : 12
Điểm kinh nghiệm : 12
Ngày tham gia : 28/08/2011
Nơi làm việc : dong a sipping
Đến từ : bien hoa
Bài gửi by mvt989 on Thu Nov 24, 2011 5:45 pm
Hi! Smile
Có bản Portable không bạn? Nếu có cho mình xin nhé!
Thank so much!
mvt989
mvt989
Tổng số bài gửi : 14
Điểm kinh nghiệm : 14
Ngày tham gia : 05/10/2010
Nơi làm việc : Đọc truyện trinh thám
Đến từ : Thanh Hóa
Bài gửi by Nguyen Trung on Tue Mar 20, 2012 2:26 pm
thanks pro!
Nguyen Trung
Nguyen Trung
Ngày tham gia : 04/04/2011
Bài gửi by jupiter*planet on Tue May 29, 2012 7:38 pm
tks parekoi.hjhj.
jupiter*planet
jupiter*planet
Tổng số bài gửi : 10
Điểm kinh nghiệm : 6
Ngày tham gia : 25/05/2012
Bài gửi by vandong230991 on Fri Oct 05, 2012 6:18 pm
thanks so much !!
vandong230991
Điểm kinh nghiệm : 20
Ngày tham gia : 17/07/2011
Nơi làm việc : No
Đến từ : Nam Định
Bài gửi by crazy01 on Fri Oct 19, 2012 10:17 am
cái phần mềm này chỉ tính được cho 1 tàu đã mặc định trong phần mềm mà không tính được cho tàu khác hả Bác?
crazy01
crazy01
Tổng số bài gửi : 9
Điểm kinh nghiệm : 9
Ngày tham gia : 10/10/2012
Bài gửi by Bố già on Fri Oct 19, 2012 11:37 am
[You must be registered and logged in to see this link.] đã viết:cái phần mềm này chỉ tính được cho 1 tàu đã mặc định trong phần mềm mà không tính được cho tàu khác hả Bác?
Muốn tính cho tàu nào thì bác nhập thông số của tàu đó vào.
Bài gửi by crazy01 on Fri Oct 19, 2012 3:35 pm
ah, hóa ra là mỗi cái tên tàu là không thể thay đổi được còn tất cả các thông số khác là có thể thay đổi tùy theo tàu mình.
thanks Very Happy
crazy01
crazy01
Tổng số bài gửi : 9
Bài gửi by Ax_badboy on Sun Mar 10, 2013 10:15 pm
hầu hết các link đều die hết rùi!!ko down dc nũa
Ax_badboy
Ax_badboy
Tổng số bài gửi : 9
Ngày tham gia : 19/04/2012
Bài gửi by nguyendanglam on Sun Mar 31, 2013 9:20 pm
sao tai ko dc
nguyendanglam
nguyendanglam
Ngày tham gia : 31/03/2013
Bài gửi by oceanustran on Sat May 04, 2013 7:35 pm
vẫn load bình thường ...!
oceanustran
oceanustran
Ngày tham gia : 04/05/2013
Bài gửi by vanquan on Wed Nov 13, 2013 2:20 pm
phần mềm Draftsurvey rất hay,thanks
vanquan
vanquan
Ngày tham gia : 29/10/2013
Bài gửi by buiduyninh on Wed Mar 05, 2014 9:59 am
sao giao diện cuả phần mềm này vào laptop của mình lại không đủ giao diện nhỉ. mr bố già cho mình xin cách chữa bệnh với.
buiduyninh
buiduyninh
Điểm kinh nghiệm : 8
Ngày tham gia : 10/11/2011
Bài gửi by mupmip on Mon Jun 29, 2015 10:03 am
Sao không óc hướng dẫn sử dụng phần mềm vậy Bố già ?
mupmip
mupmip
Ngày tham gia : 29/06/2015
Bài gửi by Bố già on Mon Jun 29, 2015 11:17 am
[You must be registered and logged in to see this link.] đã viết:Sao không óc hướng dẫn sử dụng phần mềm vậy Bố già ?
Chỉ cần nhập thông số thôi mà bác.
Bài gửi by mupmip on Mon Jun 29, 2015 2:37 pm
Em nhập số liệu rồi nhưng chỉ hiển thị True Trim là hết, còn nhập những cái tiếp theo thì không chạy Bố già ơi !!!!
mupmip
mupmip
Bài gửi by mupmip on Mon Jun 29, 2015 3:25 pm
Phần mềm của bác sao không có chỗ nhập Constant mà nó lại tự tính ở đâu ra vậy ah? ký hiệu IMo no và Oficial no là nhập giữ liệu gì vậy Bố già?
mupmip
mupmip
Bài gửi by Bố già on Tue Jun 30, 2015 11:01 am
[You must be registered and logged in to see this link.] đã viết:Em nhập số liệu rồi nhưng chỉ hiển thị True Trim là hết, còn nhập những cái tiếp theo thì không chạy Bố già ơi !!!!
Bác chỉ được nhập dữ liệu vào ô màu trắng thôi, ô màu vàng là máy tự tính nha.
[You must be registered and logged in to see this link.] đã viết:Phần mềm của bác sao không có chỗ nhập Constant mà nó lại tự tính ở đâu ra vậy ah? ký hiệu IMo no và Oficial no là nhập giữ liệu gì vậy Bố già?
Constant máy tự tính sau khi bác nhập các dữ liệu của tàu. Bác vào Ship Data -> Ship Particulars -> nhấn Ctrl+N để đặt tên tàu và nhập thông số tàu. Khi giám định thì nhập dữ liệu vào các ô màu trắng thì CS tự tính.
Bác xem thêm cuối post này: [You must be registered and logged in to see this link.]
IMO No.: [You must be registered and logged in to see this link.]
Official No.: [You must be registered and logged in to see this link.]
Bài gửi by cocuca on Mon Jul 06, 2015 3:03 pm
Bác Bố già ơi !!!! làm ơn cho e hỏi chút, cái ô Dist.fm.PP thì điền thông số gì hả bác, e mới vào nghề nên chưa hiểu hết được mong bác giải đáp giúp e
cocuca
cocuca
Ngày tham gia : 06/07/2015
Bài gửi by Bố già on Mon Jul 06, 2015 3:09 pm
[You must be registered and logged in to see this link.] đã viết:Bác Bố già ơi !!!! làm ơn cho e hỏi chút, cái ô Dist.fm.PP thì điền thông số gì hả bác, e mới vào nghề nên chưa hiểu hết được mong bác giải đáp giúp e
Dist.fm.PP (Distance from Perpendicular): khoảng cách đến đường thủy trực. Vì dấu mớn nước không được đánh dấu ở ngay đường thủy trực mà được đánh dấu ở chỗ người đọc dễ quan sát nên phải có thông số này để hiệu chỉnh.
Bài gửi by cocuca on Mon Jul 06, 2015 3:34 pm
bác có thể hướng dẫn e làm 1 bài toán trên bằng phần mềm này được ko ạ, cảm ơn bác trước nhé !!!
cocuca
cocuca
